Not arguing here, but from experience .. when using steppers, the faster the screw the greater the chance to miss steps. (tool load)
I will also ad this link as Fred now ships from Germany. https://www.aliexpress.com/store/pro...612.0.0.PXFXn5Last edited by Paul3112; 21-04-2017 at 09:51 AM.
21-04-2017 #2
Thanks again.
I have costed this out (haven't asked for a quote though) and I am up around $600 ish (+VAT etc) so that kills the whole idea for the time being, cash flow is not so good right now.
The problem seems to be that the screws would need to be 1500mm long and at that length the shipping goes through the roof, so because of that using a local company such as Zapp might be cheaper anyway.
The machine does more that earn it's living so I'll save up the pennies over the next few months.
Dave
21-04-2017 #3
24-04-2017 #4
24-04-2017 #5
24-04-2017 #6
It's not a backlash problem I don't think from reading the thread, its whipping of the leadscrews because he's driving them past their max speed to get the speed he wants to machine his materials i.e. beyond the capabilities/limits of his machine. Belts, R&P or ballscrews are the only solution really to machine at the speeds he wants.
Alternatively slow the feed and also RPM of the spindle until there's no whipping......
26-04-2017 #7
600$???
The link i pointed you to is much cheaper.
Also maybe your design is not good. Meaning you drive the screw directly or belted? As when belted the screwis acual length, not the length of your machine. And as that could mean 20-30% longer than actual length necessary.../when screw is end driven directly/
Dont overthink it. Buy 2 screws you need as cheap as possible as you find them. Then you will upgrade rest at a later time. Accept that there is no other way and concentrate how to achieve the best result. All else is no better than what you have now.Last edited by Boyan Silyavski; 26-04-2017 at 06:40 AM.
building MK2 with rack and pinion
By universally in forum Machine DiscussionReplies: 3Last Post: 23-12-2015, 01:54 PM -
Ballscrews or rack and pinion? What module of rack and pinion is the best?
By masinecc in forum Rack & Pinion SystemsReplies: 7Last Post: 14-04-2015, 02:16 PM -
rack and pinion
By D-man in forum Rack & Pinion SystemsReplies: 9Last Post: 20-10-2014, 10:42 AM -
coloured delrin/acetal uk suppliers?
By dazza in forum Marketplace DiscussionReplies: 5Last Post: 26-05-2014, 12:35 PM -
Rack and Pinion
By pmcb1011 in forum Rack & Pinion SystemsReplies: 3Last Post: 31-05-2011, 11:55 AM
