    My CNC has been working very well, and suddenly stopped. Initially I thought the cause was a loose connection with the USB. I solved that, but now I cannot get the Router to work. Everything else is 100%OK. X,Y & Z all perform as required, however the actual Router is not spinning. Mach3 also indicates the expected router speed.but then nothing !!
    I live in the Bristol area, and am seeking a "Hobby" Engineer, who I could seek support from. Does anyone have any suggestions to help me.
    In anticipation .... thank you
    Hi Malcolm and welcome to the forum.
    It would help if you supplied some more details and some pics of the machine is the router (spindle) connected via a VFD etc
    Clive, My problem is my age (80) and not clever with anything electrical !!. I will collect all the info I have, and post in the next 24 hours.
    MANY THANKS
    Malcolm
    Quote Originally Posted by Malcolm View Post
    MANY THANKS
    Malcolm
    Clive, as promised here are 2 photos of my machine a GX 6060, that Imported from China. In addition I attach photos of all the items installed.
    I am not sure what other questions you want answered, but ask, and I will try to answer
    Best wishes, MalcolmClick image for larger version.
ID:	21428Click image for larger version.
ID:	21429Click image for larger version.
ID:	21427Click image for larger version.
ID:	21430Click image for larger version.
ID:	21431Click image for larger version.
ID:	21432Click image for larger version.
ID:	21433Click image for larger version.
  1. Mach3 Problems problems problems.
    By ECCO in forum Artsoft Mach (3 & 4)
    Last Post: 09-07-2016, 10:07 AM
  2. 2.2KW 3HP Inverter help
    By adamh in forum Spindles & Drive Motors
    Last Post: 31-07-2015, 09:21 AM
  3. cnc 3040 and mach3 problems
    By hoggy in forum Machine Discussion
    Last Post: 11-10-2014, 10:58 PM
  4. Mach3 PC problems, help please....
    Last Post: 30-01-2014, 07:05 PM
  5. homing problems in mach3
    By johngoodrich in forum Artsoft Mach (3 & 4)
    Last Post: 17-09-2011, 08:28 PM
