15-06-2015 #1
Hi
I have a quantity of 25mm with a 1.6mm wall thickness polished stainless steel tube I was wondering if it would be possible to run round (LMU type) linear bearings on it. The stainless steel tube definitely seems harder than mild steel tube but it may not be as hard as proper ground linear rail. Its for a wood router so its probably not getting that much abuse and the difference in accuracy is not going to be a factor. I am wondering if the small contact area of linear bearing will wear the tube or even if the tube will deform under the pressure of the bearings. Has anyone tried this?
Notching 316 stainless tube on my CNC mill cutter tip choice
By suesi34e in forum Metalwork DiscussionReplies: 0Last Post: 29-06-2014, 02:06 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
RFQ: RFQ: Micro Precision in Stainless Steel.
By mikewatch in forum Projects, Jobs & RequestsReplies: 3Last Post: 12-04-2013, 11:49 PM -
stainless steel fasteners - quality
By dsc in forum Metalwork DiscussionReplies: 7Last Post: 30-11-2012, 12:35 PM -
FOR SALE: ballscrews, supported linear rails, linear bearings, complete kit. for sale
By cutter in forum Items For SaleReplies: 0Last Post: 04-12-2011, 03:23 PM
