    I keep reading , my brain has boil
    Excellent. Now a test to see if it is working...
    You probably want to machine construction foam up to 300mm thick, 20mm aluminium sheet, maybe with alternate heads for 3D printing, plasma and laser cutting. I mean, you want to keep your options open, right?
    Now I am burned!!! Lol
  3. Quote Originally Posted by Nickhofen View Post
    i've about the same dimensions take a look at my build log here
    http://www.mycncuk.com/threads/8717-...irst-cnc/page3
    Quote Originally Posted by pierantoine View Post
    Hey thanks,I'll check it tonight after kids go to bed!
  5. Quote Originally Posted by Nickhofen View Post
    if a 2:1 ratio why not a 1620 or 1610 if you wants better precision...
    That is another question for my potfolio I guess.
    Design of the x axis, I prefer to build it tapered and to use bolts ,with minimum welding, since it is one man job and better to handle, plus I want to avoid metal stress.
    Please feel to coment the design.X axis is made from 900x90x90x4mm steel structural sections.
  1. First cnc build drive advice needed
    By threedee in forum Gantry/Router Machines & Building
    Last Post: 25-05-2016, 11:12 PM
  2. Build log. Design advice needed.
    By eurikain in forum Gantry/Router Machines & Building
    Last Post: 25-06-2015, 06:53 PM
  3. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  4. BUILD LOG: New cnc router build looming, advice needed
    By Mad Professor in forum DIY Router Build Logs
    Last Post: 06-11-2012, 08:12 PM
  5. new mashine build advice needed
    By Finrod in forum Milling Machines, Builds & Conversions
    Last Post: 14-10-2008, 11:05 PM
