Page 16 of 16 FirstFirst ... 6141516
    Nice...clamp clamp!!
  2. The Following User Says Thank You to Nickhofen For This Useful Post:
  3. #2
    Haha :D what are you planning on clamping there Mr crazy-clamp? ;)
    My first clamp I made was aluminium extrusion and it flexed when I ran the machine over 2m/min when cutting so I went a little OTT with box section steel and toggle clamps lol.
    They're <£1 a clamp that's why I went so OTT, you only need 4 per part, gives me a clamping range of 15mm-28mm thickness, need to put holes in the end metal plates yet so I can use T bolts to attach and adjust the clamp. Going to use 2 per plate so 4 per "clamp for 8 T bolts in total. Wing nuts for tool free adjustment and speed.
    There's 28 clamps on this cost ~£32 to build I had the box section, the annoying bit was drilling and tapping 112 holes to fir the clamps, box section is 3mm wall thickness. At the moment everything I want to work on is 20-25mm thick although I might make another one to do thinner material, need access to a steel milling machine for that.
    You'll see I already lost one the rubber clamp bits will need to put a new one on, if you use these You should do what I intend to do and drop a nylox nut on instead of the normal one so it won't come loose.
    Works really well only need 4 clamps per part so lot's of redundancy.
  5. #4
    I had to move the machine which meant rewiring so I took the opportunity to replace the linuxcnc with a DDSCV
    Going to add a stop and start button.
    I have a stainless steel controller box I recovered for free but needed to make a new mounting plate.
  6. #5
    f750's Avatar
    Lives in herne bay, United Kingdom. Last Activity: 21-11-2022 Has been a member for 9-10 years. Has a total post count of 13. Received thanks 1 times, giving thanks to others 0 times.
    I have built a machine following this and the Joe Harris build. I am using the same BOB and having read all the way though my question is, I am using a dual ball screws and could you confirm the wiring on the inputs for the limit switches.
    Cheers Tony
  7. The Following User Says Thank You to f750 For This Useful Post:
  8. #6
    KevA's Avatar
    Lives in Ripley, United Kingdom. Last Activity: 08-01-2026 Has been a member for 6-7 years. Has a total post count of 5. Received thanks 1 times, giving thanks to others 4 times.
    That Z axis assembly looks well hard lol
