18-11-2018 #621
I'm going to assume you want to use the limit switches as home as well.
What software are you using on the computer?
Do you want to dual home the gantry?
How many home switches do you have?
On that 5 axis BOB I have P12, P13 & P15 you would normally use for X, Y & Z limits in linuxcnc or Mach 3 you can also assign these pins in software so what matters is you're wiring matches how you assigned the pins.
If you want dual homing you can share the input as long as it's not the same axis. Needs to be set in software. You can also use the p11 tool setting as another axis.
Good good you were following Joe's Build too lol, I'm kind of the Benny Hill of mycncuk lol but with worse music and uglier women ;)Last edited by Desertboy; 18-11-2018 at 09:17 PM.
18-11-2018 #622
Cheers for the reply,I am using Mach3 as my software and have the machine working on it. I am at the stage of fitting the limit switches, I want to do dual homing on the gantry and keep the tool setting function.
18-11-2018 #623
you have 3 inputs pins and 4 inputs X, Y1, Y2, Z
Something like
P12 X
P13 Y1
P15 Z & Y2 set as shared. Since you use Z the least seems the simplest solution. Setting the pins in Mach 3 should be easy but I don't use it so you'll have to ask others.
There's a good forum for Mach 3 as well for setting up.Last edited by Desertboy; 18-11-2018 at 09:41 PM.
24-11-2018 #624
Bought some kit, also got a grinder and an impact driver coming.
https://www.powertoolmate.co.uk/
Got lucky they sent me the case for drill and impact driver (I only bought the drill) and then I bought the impact driver without case so it worked out.
Over £200 cheaper than buying from screwfix for the drill, batteries, saw, impact driver & grinder including the VAT.Last edited by Desertboy; 24-11-2018 at 01:36 PM.
The Following 2 Users Say Thank You to Desertboy For This Useful Post:
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
