30-06-2017 #61
30-06-2017 #62
When I finally finish my build I'm going to order 100 of each type for the 45 series extrusion for stock so I won't ever have to pay stupid prices again lol.
When I finish my machine I will have used nearly all my extrusion up so need to go on a pikey mission round the scrap yards to see what I can find ;)
Or just buy that machine I linked to if you don't first lol.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
01-07-2017 #63
Right bought a 13pcs collet set so I suppose I ought to get some endmills ordered open to suggestions, I want to be able to cut MDF accurately and I want some aluminium millers.
I do know I will need ballnose end mill at least, I most confused on the size I should buy.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
08-07-2017 #64
Almost ready to have the aluminium plates made was going to send cad models and discovered that my clone rail has HR15 blocks not HG15 blocks!
The difference is probably about 8mm in mounting height lol going to need to take some accurate measurement s and rethink the gantry as this is where the HR15 is going.
the other choice is move some HG carriages across but worried the clone rail will be made of crap steel and proper HG carriages will wear it prematurely so think maybe I should stick with the original carriages for the clone rail.
Once I have the mounts in pace I can finally start getting movement on the XY&Z axis ;)
I may never have got on with my Prusa Mendel 3d printer but I could never have had even a chance at building this without it ;)Last edited by Desertboy; 08-07-2017 at 11:03 AM.
12-07-2017 #65http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
14-07-2017 #66
Need to get some wiring for the stepper motor's as cables are far too short and need to be extended will something like this suffice?
http://www.screwfix.com/p/time-round...FSIS0wodF9IDHA
All my Nema 23's are 4 wire.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
14-07-2017 #67
Something like this would be better 4 core CY cable 1mm. https://www.cse-distributors.co.uk/c...creened-cable/
14-07-2017 #68
14-07-2017 #69
14-07-2017 #70http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
