01-09-2017 #161
Stupid question probably but where do I use the circlip that came with the BK12/BF12 fittings? Not seen any decent vids on how to actually assemble the ballscrew & fittings seems easy enough but the circlip is confusing me lol.
I'm guessing the circlip goes the floating end? But could have done with some instructions lol.Last edited by Desertboy; 01-09-2017 at 04:24 PM.
01-09-2017 #162
On the floating end of the screw BF end there is a groove for the circlip that goes on after the bearing. The the BF block will slide on the bearing and should sit about half way in. The reason is so that if the screw expands it can do so at the BF end as the bearing will slide in the block.
02-09-2017 #163
Assembled a bit more started to think about energy chain placement.
there's 2 bolts in the BK12 mounts that bolt into T nuts but 1 of them is counterbored and under the BK12, The A2's are then upside down and bolted from above was difficult to do forgot I meant to change the A2 bore to a captive nut but worked out ok in the end. Every bolt has a non slip washer under it.
04-09-2017 #164
My AM882'S have being ordered today delivery time is quoted at 7 to 12 working days, so looking at the PSU next.
Does anyone know how the stall protection works? Looking at the manual it sets a pin high until power reset? in which case I could make it work with the Arduino but got a breakout board and a core duo with a parallel port to run linux cnc on.
Went 2nd hand (Cheapest on ebay) of course lol
http://www.ebay.co.uk/itm/Used-AM882...AAAOSwe-FVAS~f
4 of them, 2 reasons this has quick shipping (1-2 weeks) the new ones at ~£65 have 4-6 weeks shipping and well I save almost £70 which will pay nicely for the PSU and buy a couple more breakout boards (£3 each should buy spares).
They offer a year's warranty which is pretty much worthless lol but I bet they'll be fine for many years to come unless my wiring is dodgy. Going to solder my wires to extend them and make sure the soldered points do not move!Last edited by Desertboy; 04-09-2017 at 12:30 PM.
04-09-2017 #165Why would you even consider an Arduino What are you going to drive it with? Remember a simple BOB will only have 5 inputs. You will need two for slaved homing that means three left unless you put two PP's in the PC.Does anyone know how the stall protection works? Looking at the manual it sets a pin high until power reset? in which case I could make it work with the Arduino but got a breakout board and a core duo with a parallel port to run linux cnc on.
What wires?Going to solder my wires to extend them and make sure the soldered points do not move!..Clive
04-09-2017 #166
My nema 23 wiring isn't long enough so need to extend it was intending to make sure the soldered connections don't have stresses on them, I was going to use an arduino originally and I will connect it up just to make sure all the axis are moving properly whilst I'm waiting for the AM882's.
Some of my nema's have plugs crimped onto them so I could test the motors but will cut the plugs off and solder the wires.Last edited by Desertboy; 04-09-2017 at 05:30 PM.
04-09-2017 #167
04-09-2017 #168http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
04-09-2017 #169
04-09-2017 #170
I assume the stall protection is automatic in the driver... I don't have the AM882's but mine just does it all automatically - The only extra wiring to consider is the alarm wiring that then lets the motion controller know there has been a fault so that it stops rather than tries to carry on with an axis dead.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
