29-08-2017 #11
Machinist's square is one option, but they are expensive. I got a 200mmx130mm one (square to 0.005mm/150mm or better) from starret for about 80 quid with a 20% off code.
You can make a less perfect square work by flipping it and averaging the results, but once you get into the lower ranges of measurement just the flatness of the edge can become problematic and that's harder to cancel out.
You can also drill a square with diagonals that you can measure with eg a digital calliper (100x100mm square will give an easy to measure distance that your typical digital calliper will reach). Insert some dowels and measure the corner to corner distance. If both corners are equally spaced diagonally then it's square, if one is longer than the other then it's forming a parallelogram and is leaning towards the top corner of the longer diagonal...
One problem you'll probably encounter, which I also have on my current machine, is that your extrusions aren't particularly flat or straight. You will have varying curves along the axis rather than a perfectly straight line which makes fine tuning the squareness extremely difficult if not impossible as it varies from one section of the bed to another... so you just have to do the best you can.Last edited by Zeeflyboy; 29-08-2017 at 04:32 PM.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
