23-09-2017 #11
Plenty of people use microswitches, and that will probably be fine. I use inductive sensors, as much as anything for convenience in mounting, but in practice I doubt that you will have any issues. The other point is that once you start wiring inductive sensors in series to share a single BOB input, you need to make sure that you have enough volts to drive them as there is a bit lost in each sensor in the chain. I'm putting this crudely and hoping that the experts will let me off this time!
Do you have a pointer to any documentation on the BOB? My guess is that it will work fine with just a 5V feed. However, I doubt that the inputs have pull-up resistors as they are probably opto-isolated and pull-ups are a little bit trickier in that case. It's not like the Arduino where you connect directly to the input pins on the CPU chip. On the plus side, it's a bit more difficult to blow up a BOB than an Arduino! I strongly suspect that if you connect the switches (just one, or a number of them in series) between +5V and the BOB input, it will work fine, but I wouldn't guarantee that without looking at the documentation for the BOB, or even a sample "this is how you wire it" diagram.
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
