19-10-2017 #11
Finally skanked a 2nd hand piece of ply to use for shelves almost having to go buy one there :)
Wired up a little more, now I need the CY cable so I can wire to the motors, limit switchs will go on last as I haven't even decided how to mount them yet past a brief look around the machine for ideas.
I think I might need to use the machine to make the limit switch mounts as I want them to be rock solid out of aluminium rather than 3d print them.
I hope I wired the emergency in correctly (Only 2 of 4 wired in at moment) wired them to a barrier connector block joining the live to live and neutral to neutral than ran 1 wire each to the right inputs on the BOB.
I assume it's similar with the limit switches, wire all the grounds to 1 connector and then from there to the common ground (same as emergency) then wire the limit lives. X&Z to the X input, One Y limit switch to the Y input and the 2nd Y limit switch to the Z?
I did ask before but forgot the answer what power should I feed the BOB
Looks like theres 2 PC live 5v's inputs, with 1 gnd, also 12-24v input and a 5v USB? Which one should I use? I'm going to have this sat next to the pc that will control it and I'll get a 4 pin molex extension to tap a spare output from the PSU so will have both 5v & 12v available.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
