01-11-2017 #281http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
01-11-2017 #282
01-11-2017 #283http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
01-11-2017 #284
How are you planning to use the dual home switches (Y axis in your case?). Generally you do this for gantry squaring, but only if your motion controller supports this (and not all do!). I don't think that Mach3 can do this either. I have the same problem on my own machine, by the way, and not trying to pick holes in your design. It's just one of those things that isn't obvious until you come to try to do it...
Personally, I home my dual-axis using just one home switch and manually tweak the other side for squaring purposes as my motion controller is no help at all in this area.
01-11-2017 #285Neale I think Mach3 can do dual homing. UNCHECK "Home Slave with Master" in General Config. You may also need to modify your Ref All script to use RefCombination() to get the two sides to move together.I don't think that Mach3 can do this either...Clive
01-11-2017 #286
I'm going to try linuxcnc which does support gantry squaring (Whether it works with my BOB we'll see) at least in 2.8, a quick google and it appears mach 3 does as well.
I'll try mach 3 as well, I planned a 2 pc setup for the cnc machine just in case with windows 7 & Fusion on one and the other with linuxcnc that way I can try both easily and have convenience of cam next to the machine.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
01-11-2017 #287
01-11-2017 #288
I stand corrected! I'm using a CSMIO-IP/M which handles dual-axis and homing, but doesn't handle squaring (i.e. homing each end of the gantry simultaneously-but-separately, if you see what I mean). Because the CSMIO does some stuff internally and Mach3 does the rest, it's not always easy to see what is a Mach3 feature/restriction and what comes from the CSMIO. It's unfortunate that one of the things that drove me towards Mach3 was that LCNC, at the time, didn't support dual-axis properly. Sorry if I've mislead anyone.
02-11-2017 #289No you have not. That is the beauty of a forum its generally self correcting I certainly need it.Sorry if I've mislead anyone.
and I value your input.
02-11-2017 #290
Just tought of something..
I'd you have the limitswitch like that and get some overshoot you will crush the switch ;)
I.e if the machine is on a rampage and go full speed into the side.. If you have the switch in a way so the machine will only touch the trigger but pass the housing of the switch it should stop in a few mm :D
Make any sense?
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
