08-11-2017 #11
One easy way to discharge a capacitor is to cross the two cap legs with a screwdriver that has an insulated handle, prior to do that you must remove the plug from the wall. Another way is to connect a consumption at the capacitor leads, like a resistance or even a light bulb, prefer the light bulbs with the wire inside no the neon light or led.
If you want to measure a capacitor and you do not have a capacitance meter, but you have a voltmeter,first disconnect at least one of the cap legs,then put the multi meter at resistance measurement place the leads of the meter on the leads of the capacitor and see the resistance measurement at the meter screen rise until it shows infinity , this gives you an idea that the cap is ok if ohms start to rise and then stop at a low indication the capacitor is grounded. Other way is to place a 9volt battery at the cap leads and then measure the voltage with your voltmeter, if the voltage drops rapidly this shows a bad cap.ForLast edited by Nickhofen; 08-11-2017 at 05:48 PM.
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
