    Can you take a resistance measurement at the coil that you do not have continuity? If you put your multimeter at continuity scale you get a bazing sound of a reading only if resistance is low,I think up to 10 ohm but I am not sure if it is a little higher or change between the brands of the meters,if resistance is higher you have to take a measurement with the ohmmeter.
    I've ordered another transformer, will check the existing transformer though
    https://www.maplin.co.uk/p/2x50v-100...nsformer-a74qj
    It's 50v per output core
    I hope there's no issue going oversized with a 1000va transformer but I didn't realise they had 625va one and this was 1/2 price same make as rapid.
    Saved enough cash on the transformer that I just managed to buy a new AM882 as well with fast shipping.
    Normal version not am882h.
    One good bit of news the new parallel port card came I fitted it and parport recognises it so linuxcnc should at least work and I bet mach 3 does to.
Name:	toroidal transformer 2.png
    I got it wrong before there's no continuity between blue and grey OR violet and brown but there is continuity between grey and violet I guess this means both thermal fuses are blown.
    One question about the new transformer I know I wire on the input side the brown and blue to the mains, the grey and violet together as before. On the output I wire the orange to the black and the yellow to the red then wire them to the the rectifier is that correct?
    Would wiring a 5amp plug fuse to the PSU input give some protection to without tripping out in normal usage?
