12-11-2017 #2
Have ordered a 45v 1kva which will solve the problem whilst I'm waiting I took the time to start stripping out the box and recovered some nicer wiring conduits. Also fitted a proper stop switch to it.
Friend is going to fibreglass repair the damage for me I might even paint it ;)
There's loads of space in here should I put the transformer in here as well and fit a 4 120mm pc fans two blowing in across the am882's and two sucking out the side of the transformer and leave a nice gap so the air can flow, I want to make sure the caps get good air flow over them.
It would be good to fit the transformer at the top of the box but it weighs 8kg making the box top heavy so it'll go at the bottom if i do fit I think the key will be good air flow and lots of it. I have a better on/off switch which is rated to 2hp (I think might be 3) ac3 so I think should be ok for the PSU.Last edited by Desertboy; 12-11-2017 at 09:11 PM.
12-11-2017 #3
12-11-2017 #4
None of my CNC modules get hot, i would think one fan would be ok, filtered inlet then fan with a vent at other side of cabinet.
Caps will/should not get hot or even warm.
12-11-2017 #5
12-11-2017 #6
It's easy to worry about overheating but in practice, it's not a big problem on our size machines. On mine, I have two 12V fans just so that they cover a larger area and push a bit of breeze across the stepper drivers but I have wired them in series so that they run fairly slowly. Moves more than enough air. Similarly, I run the 12V spindle cooling pump on 5V and that works fine as well.
I also bought a 50V transformer for my machine (from Rapid Online), then realised that it was going to be a bit too high. Once you take into account the fact that input voltage can be some way above nominal, and the output voltage is a few per cent high to allow for voltage drop at full load, then it's easy to start nudging that 80V. In my case, I rang Rapid the day after the transformer arrived and they were happy to swap it for 45V, and even arranged a courier to pick up the old one. Good people to deal with. I'm now running at a nominal 68V which is bang on the money.
12-11-2017 #7
I'm going to fit a inrush current limiter ntc thermistor
https://www.ametherm.com/blog/inrush...s-got-you-down
I think this is suitable
https://www.ebay.co.uk/itm/282728849186
as far as I can tell I just wire this inline to the mains, anyone had any experience of them?http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
13-11-2017 #8
I wouldn't bother, unless the power on surge is a problem, as it's just something else to give potential problems.
The Following 2 Users Say Thank You to m_c For This Useful Post:
16-11-2017 #9http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
