Page 44 of 63 FirstFirst ... 34424344454654 ... LastLast
  1. #431
    That's my board so we'll see tomorrow ;)
    Really liking the 3d mouse gives you so much more control over how you view your model.
Name:	3d mouse.jpg
  2. #432
    Going down to south park ;)
  3. #433
    Make it, show it, love it!
  4. #434
    The southpark figures are 3d illustrations?? The wood grain looks wrong to be real cuts?
  5. #435
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 6 Days Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    Renders from within Fusion 360. Shows how good they are, the need to check / question :-)
  6. The Following User Says Thank You to Chaz For This Useful Post:
  7. #436
    Chaz is right there Fusion 360 models I then "coloured" using different woods in physical material.
    I was playing with different ways of making cad models from bitmaps
    The South Park figures were a simple spline trace over a canvas, Obey from They Live (Cracking film) I used Inkscape trace bitmap function to vectorize the image then used the SVG to extrude from.
    This is one I did from a photo of a friend this took a fair bit of processing in both gimp and Inkscape before I could get a usable extrusion will need cleaning up before I make it.
    Also going to check out image2gcode built into linuxcnc to see what engraving fun I can have ;)
  8. The Following User Says Thank You to Desertboy For This Useful Post:
  9. #437
    Was playing in fusion only took 40 mins but not sure how I'd drive the long axis, I think needs to be R&P but have no idea how to set up a dual pinion anti backlash setup. The other choice 2* 2.7m 2510 ballscrew's with rotating ballnut's as at the length it's going to be a skipping rope if I try and rotate the screw.
    Does anyone know how I invert the axis in linuxcnc? Using the beta dual ballscrew on the Y so need to edit the hal or .ini to do it as the wizard doesn't support dual motors.
    Alright Fusion buffs when I copy an object how do I break the association so my edits to the new object do not effect the original?
  10. #438
    Man, do i need to brush up on Fusion, 40 minutes? would have taken me a week :) Thats if i could figure out where to start
  11. #439
    Are you sure you need dual pinions if using r&p?
    I think the more common option is to spring load the pinion against the rack.. have you checked cncrouterparts design with a pivotplate or the mechmate as it uses similar design.
    And I agree about your fusion skills! Impressive!
    I find solidworks much more intuitive but I have a really old version so I guess fusion tutorials are on that to-do list ;)
  12. #440
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Dave
    For twin screws you need Linuxcnc V 2.8 master if you want independent homing. I you want to reverse on of the motors then you can just swap the phases around on the motor.
    What version are you using?
