Hmm Interesting on the 64bit windows ;)
Having access to the source for the kernel helps ;) There's a few real time kernels which you can use with linuxcnc not sure if any have an advantage or difference over the stock kernel included with the livecd but I do love the fact that there are several options. I remember reading the linuxcnc real time kernels are again hacks and not true real time kernels but good enough for the machines to work ok. Real timish was the term I saw being used which I love ;)
My obvious upgrade path is Mesa 7i73 which I'm eyeing up ;) I think I need to invest in a decent table saw (Or a vertical panel saw like in B&Q) first so I can process the wood into usable pieces.Last edited by Desertboy; 31-12-2017 at 01:00 PM.
31-12-2017 #2
Since I'm only working wood/mdf/ply can I leave the spindle at 24000rpm/400hz all the time for now? I haven't connected the vfd to the BOB yet although I put the 12v power to the BOB in place so easy connect.
01-01-2018 #3
Happy new year!
My resolution is to learn a lot more this year than I did last ;)http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
01-01-2018 #4
Happy 2018!
02-01-2018 #5
Ordered myself a stop button living it up in the new year ;)
http://www.ebay.co.uk/itm/132443180667http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
03-01-2018 #6
My elephone S8 came today not bad 2 weeks no import tax as well which is always good. £185 can't grumble it's lovely and at a price that when I break it in 6 months I can live with it lol.
I won't have the spindle so low in the mount I only have it that way until I fit a physical limit and limit switch so I can't run the Hiwin's off the rail on the Z axis.
I intend to put a bolt through the bottom Hiwin fitting that sticks out so it's blocked off and the carriages cannot come off.
This is a photo with my elephone better than my fuji camera so happy with it ;) You can see my make shift clamps but also going to have a vac bedLast edited by Desertboy; 03-01-2018 at 02:09 PM.
03-01-2018 #7
Nice, that phone does look good, I'm struggling with a dying iPhone6 and can't afford the new apple stuff so i'll probably look at one as well.
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
