    Yes Mesa 7i76e
    I think you should take a step back and start with baby steps with Lcnc. Start by getting the homing sorted etc.
    I have read your posts on the Linuxcnc forum and seen your ini and hal files they are different to the ones you have posted here try and be consistent with what you are asking.
    I think your limits problem is that the machine does not know where it is, so get it homing first. I know where there is a working config for the 7i76e but it is for a plasma but is near enough.
    edit : And just to keep you sane https://www.youtube.com/watch?time_c...&v=bAdqazixuRY
    The first ini I posted on linuxcnc didn't work I had set up A axis, the one I posted in the quote should have been the same one as I posted here but too early to check lol.
    I've been looking at 7i76 for a little while but was confused on if 7i76 did step generation or you needed the 5i25 combo for step generation.
    https://mesaus.com/index.php?route=p...&product_id=78
    I guess what I'm asking is can I get away with buying the Ethernet version of 7i76 on it's own?
    I'll get the switches on today hopefully my M3's have been shipped so should be today they come but I did try no forced homing as well as manual homing which I read should have made this go away but it did not lol.
    When I press - on the manual move buttons for the Z axis should it move up or down? I'm guessing down at the moment mine moves up lol.
    My friend keeps telling me to just use Mach 3 but if I do then I'd set up a pirate see if it works ok do some cuts then buy it and the inner tight guy inside me says just learn linuxcnc you idle twat lol and then the £200 you were going to use for Mach 3 will buy a 5i25 and 7i76 with the saved money ;)
There are currently 17 users browsing this thread. (0 members and 17 guests)
