23-01-2018 #10
4.5m/min seems to the top speed for the gantry which is where I thought it would be (Screw whip is just over 1000rpm for this screw, 5mm pitch)
The Y axis is a lot speedier been able to run that at 7m/min so far might be able to push it a little further screw whip is just over 2000 rpm for this screw, 4mm pitch,
I'm going to use a 4nm motor on the gantry (2nm at moment) with the 2010 screw.
Of course the Y axis will be turned into R&P when I upgrade but for now if I can the whole machine running at ~8m/min I'll be a happy man.
In theory I should be able to spin the 2010 so I can get 13m/min but that's really down to how accurate is the mounting and how good are the bearings I bought the cheapest screw so the answer is probably not that good lol.
I'm going to go for 2.5m travel on the Y because if I'm going to do it I might as well do it right so I can process 8*4 not that I would ever want to touch that horrible crap I'm a real wood kind of guy.
Also the cost difference is couple of hundred quid now.
As Christian Slater said it's better to have a gun and not need it than need a gun and not have it just replace with cnc travel ;) Might not be quite as catchy.
I'm using a 2.9ghz I7 to generate pulses not sure where my speed limit will be but I know the controller will need upgrading going to get what Clive suggested as I want to stick with linuxcnc.
7i76e I think but of course I'll order the right one from the States.Last edited by Desertboy; 23-01-2018 at 05:14 PM.
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
