23-01-2018 #12
I could do a Dual gantry, been toying with it for a while on a switch so I can use either gantry with shared electronics, PSU, etc & 2 different profiles in linuxcnc. Share the rail, one R&P driven and the other driven by the 2 1m ballscrews. All seperate limit switches will be crazy wiring lol but not impossibly crazy.
When not in use I'll park the spare gantry out the way past the limit switches for the gantry that's working.
Cost is ~£600 with another 2.2kw spindle which is cheaper than building another machine of course and best of both worlds although I can only work one at once of course but since aluminium will very rare but the cost of outsourcing anything I want to do so high I can see it's worth it.
I could keep the 1605 ballscrew I have now for the 2nd gantry after all it doesn't need to be fast I only need fast for wood as my designs will fill the bed fior almost every cut and will be 3d milling 50+ pieces out of every bit of wood this will get old quick. At the moment going to have to cut real wood sheets in 1/2 to process them.
Doing the cam in fusion is getting old quick as well lol at some point will probably buy Vcarve pro.
Dual gantry opens up many possibilities although not with out headaches, but I could pimp it out with AM882's all round (So 8) and run both at the same time and be glad I got that 1kva transformer after all.
This would turn it into 1 1m*1.2m machine and 1 m*1.8m machine so would need 3 setups but opens up considerble time savings for certain things.Last edited by Desertboy; 23-01-2018 at 07:39 PM.
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
