23-02-2018 #16
https://forum.linuxcnc.org/38-genera...nerator#106403
So we shall see I guess I'm only using 8 (maybe 16) microsteps with nema's. Not worried about the other inputs at moment but at some point I will get a daughter board for it and if I find speed is an issue that will be sooner than later lol. I assume I can set the khz within a certain range for each axis? If I can run at 50khz per axis I'll be more than happy for now.Just remember most cheap parallel port breakout boards are not designed to be able to handle the speed potential of hardware step generation. They often have relatively slow optos, not a problem with a slow parallel port, and shouldn't be with an ordinary step motor config (unless your using really high micro stepping and spinning fast). But it can be a problem with high resolution step/dir servos.
Am I doing my maths correct?
8*200 steps *20 (revolutions in 1m) * 2 pulses per step=64000 pulses/metre
I want 10/min it would be 64000*10=640000khz then divide by 60 == 10666.66 khz per axis
Good thing about mesa is their upgradability.Last edited by Desertboy; 23-02-2018 at 07:17 PM.
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
