23-02-2018 #561
Good advice this was very old oak I tried a newer bit today didn't tear the same but still not perfect.
Just bit the bullet and bought a hardware step generator a Mesa 5i25 as my pc's not giving me the performance I can get out the machine.
https://www.ebay.co.uk/itm/272930377353
Plugs into the breakout board so no need to rewire which is good ;) I was in Vilnius last year I could have collected it lol.
This will generate more pulses than I could ever need it expands the BOB connectivity considerably but it's the pulses I can about, it can be linked to encoders for other funky stuff.Last edited by Desertboy; 23-02-2018 at 05:38 PM.
23-02-2018 #562Plugs into the breakout board so no need to rewire which is good ;)..Clive
23-02-2018 #563
https://forum.linuxcnc.org/38-genera...nerator#106403
Just remember most cheap parallel port breakout boards are not designed to be able to handle the speed potential of hardware step generation. They often have relatively slow optos, not a problem with a slow parallel port, and shouldn't be with an ordinary step motor config (unless your using really high micro stepping and spinning fast). But it can be a problem with high resolution step/dir servos.
Am I doing my maths correct?
8*200 steps *20 (revolutions in 1m) * 2 pulses per step=64000 pulses/metre
I want 10/min it would be 64000*10=640000khz then divide by 60 == 10666.66 khz per axis
Good thing about mesa is their upgradability.Last edited by Desertboy; 23-02-2018 at 07:17 PM.
23-02-2018 #564This will generate more pulses than I could ever need it expands the BOB connectivity considerably but it's the pulses I can about, it can be linked to encoders for other funky stuff...Clive
23-02-2018 #565
23-02-2018 #566http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
23-02-2018 #567
24-02-2018 #568
Life is like a box of chocolates, some bastards been in it before you and ate all the good ones leaving you the strawberry creams lol ;)
Hmmm I have a PS3 pad kicking around wonder if I can get it to work over bluetooth.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
24-02-2018 #569
Cool!
24-02-2018 #570
The Following User Says Thank You to Desertboy For This Useful Post:
There are currently 78 users browsing this thread. (0 members and 78 guests)
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
