25-08-2017 #131http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
26-08-2017 #132
What about these for stepper drivers?
https://www.omc-stepperonline.com/st...or-dm542t.html
I can probably just about scrape 4 of these and a breakout board next week and run them at 24v until I source a 48v one.
I know not as good as the EM882 I wanted but 1/2 the price and means I can start with linuxcnc.
Had a couple of hours playing in Fusion shocked how easy it is to make models I think it's only going to take me a week to transfer my turbocad skills to fusion the hard part will be the timeline which is quite different to Turbocad but I guess kind of like the part tree.Last edited by Desertboy; 26-08-2017 at 07:42 AM.
26-08-2017 #133
I have 4 stepper motors and digital drivers very similar to those from when I upgraded my machine. They were running on 40v in my machine.
Could do a bit of a deal on those if you wanted?
The Following User Says Thank You to Zeeflyboy For This Useful Post:
28-08-2017 #134
OK still need to source the drivers, would using
4 of these
with 2 of these (2 per motor)
http://www.ebay.co.uk/itm/Universal-...YAAOSwaMpZno1f
be suitable for my machine
3 of my nema 23's are 2.8amp (X&Y Axis)
the other one is unknown but based on shaft length, size and weight it's 2 amp (Z Axis).
I was going to go with AM882's but seems overkill for my application and it's unlikely I will make major upgrades down the line to my machine as it makes more sense to build another one and then sell the first one.Last edited by Desertboy; 28-08-2017 at 10:27 AM.
28-08-2017 #135If you are using a slaved axis arrangement then ideally you will need stall or fault protection to stop the gantry racking the AM882 will provide that.OK still need to source the drivers, would using
4 of these
The drives that you linked to seem to recommend 36V.
You could built a toroidal for not much more that would work better...Clive
28-08-2017 #136
28-08-2017 #137
I use 2 motors for my X axis, and I bought EM806 drivers primarily because of the stall detect. The EM806 is a later version, effectively, of the AM882. That stall detect has saved my machine from potential damage on a number of occasions when I've got something wrong. Typically, I've hit the e-stop because of some silly setup or gcode issue, and as a result the gantry has gone out of square. Not a lot, but enough to cause one end or other to bind on rapid feed somewhere along the rails. I've wired the fault signals from the stepper drivers into the motion controller and the whole machine then stops before any damage is done by one motor continuing to drive. Resetting and rehoming is a small price to pay. I reckon that if you are going two-motors rather than one-motor-and-a-long-belt, stall detect is pretty much essential.
Have you worked out how you will home the gantry so it is square?
28-08-2017 #138
I was going to assemble it first then fit (High quality) microswitches both sides of the gantry I need to work out where to fit them because I want them drilled into the aluminium so they can never move, had issues with 3d printer microswitches but they were super cheap, plastic printed mounts a nightmare on the Z. Conversly it's the X&Y that are the hassle with cnc with 3d printing they're nowhere near as important.
I've not looked at Mach 3 or linuxcnc but I have assumed that the microswitchs have some software adjustment to compensate for inaccuracy when fitting the microswitchs I know grbl (And even Marlin for 3d printers both Arduino based) does so would be shocked if they don't.
I figured one step at a time lol make router move and learn Fusion (These are at same time) then start with linuxcnc if I really struggle buy Mach3 but I'd rather use Linuxcnc been a linux used since 2005 big believer in opensource.
I did also consider inductive sensors like I set up on my printer for the Z axis but the microswitchs I'm looking at have very high repeatability and the difference in accuracy between them is marginal, when I checked the datasheets the inductive sensors had a slightly higher accuracy but lower repeatability and in the end they were both in the 0.01mm range with is probably better than my router will be lol.
I have no idea how to make sure the gantry is properly square though in the first place, pretty certain a set square isn't going to cut it lol.Last edited by Desertboy; 28-08-2017 at 12:18 PM.
28-08-2017 #139
From what I hear, you are probably on a winner with the LCNC approach. When I built my first router around 5 years ago, it had single motors on each axis so gantry squaring wasn't an issue. Just as well as I was using LCNC which had no capability to home each end of the gantry separately. I ended up going to Mach3 and a CSMIO/IP-M motion controller for the Mk2, with twin X motors. This combination works really well - except that it doesn't home each end of the gantry separately either! However, I understand that this is functionality that is now in LCNC so you should be OK when you get to that point. I have a manual process to get round this but it would have been nice to just press a button and have it all happen automatically.
I've had Z axis microswitch issues on my 3D printer - I know what you mean!
28-08-2017 #140Yes you are correct but it is only in the master branch (version 2.8) at this time and you can also alter the homing position on each axis in software just by changing an offset in the Machinexxx.ini fileI understand that this is functionality that is now in LCNC so you should be OK when you get to that point. I have a manual process to get round this but it would have been nice to just press a button and have it all happen automatically.
Have a look at Joe's excellent vids on building one.When it comes to building the PSU will need help
https://www.youtube.com/playlist?lis...zD30sZjtp_VyqYLast edited by Clive S; 28-08-2017 at 06:51 PM.
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
