Page 14 of 63 FirstFirst ... 4121314151624 ... LastLast
  1. #131
    Nice to have your PC working, CliveS point me those tutorials for Fusion360 and I found them very informative.
    https://www.youtube.com/playlist?lis...h54N-hVtLg5p6u
    You might have check them already...
    Will have to check some tutorials out but had a little "free play" last night lots of nice features made a few simple models a lot more intuitive than Turbocad.
  2. #132
    What about these for stepper drivers?
    https://www.omc-stepperonline.com/st...or-dm542t.html
    I can probably just about scrape 4 of these and a breakout board next week and run them at 24v until I source a 48v one.
    I know not as good as the EM882 I wanted but 1/2 the price and means I can start with linuxcnc.
    Had a couple of hours playing in Fusion shocked how easy it is to make models I think it's only going to take me a week to transfer my turbocad skills to fusion the hard part will be the timeline which is quite different to Turbocad but I guess kind of like the part tree.
  3. #133
    I have 4 stepper motors and digital drivers very similar to those from when I upgraded my machine. They were running on 40v in my machine.
    Could do a bit of a deal on those if you wanted?
  4. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  5. #134
    OK still need to source the drivers, would using
    4 of these
    with 2 of these (2 per motor)
    http://www.ebay.co.uk/itm/Universal-...YAAOSwaMpZno1f
    be suitable for my machine
    3 of my nema 23's are 2.8amp (X&Y Axis)
    the other one is unknown but based on shaft length, size and weight it's 2 amp (Z Axis).
    I was going to go with AM882's but seems overkill for my application and it's unlikely I will make major upgrades down the line to my machine as it makes more sense to build another one and then sell the first one.
  6. #135
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    4 of these
    If you are using a slaved axis arrangement then ideally you will need stall or fault protection to stop the gantry racking the AM882 will provide that.
    The drives that you linked to seem to recommend 36V.
    You could built a toroidal for not much more that would work better.
  7. The Following User Says Thank You to Clive S For This Useful Post:
  8. #136
    So what you're saying is stop being a tight ass and do it properly lol, ok point taken!
    When it comes to building the PSU will need help :)
  9. #137
    Lives in Plymouth, United Kingdom. Last Activity: 14 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I use 2 motors for my X axis, and I bought EM806 drivers primarily because of the stall detect. The EM806 is a later version, effectively, of the AM882. That stall detect has saved my machine from potential damage on a number of occasions when I've got something wrong. Typically, I've hit the e-stop because of some silly setup or gcode issue, and as a result the gantry has gone out of square. Not a lot, but enough to cause one end or other to bind on rapid feed somewhere along the rails. I've wired the fault signals from the stepper drivers into the motion controller and the whole machine then stops before any damage is done by one motor continuing to drive. Resetting and rehoming is a small price to pay. I reckon that if you are going two-motors rather than one-motor-and-a-long-belt, stall detect is pretty much essential.
    Have you worked out how you will home the gantry so it is square?
  10. The Following User Says Thank You to Neale For This Useful Post:
  11. #138
    I was going to assemble it first then fit (High quality) microswitches both sides of the gantry I need to work out where to fit them because I want them drilled into the aluminium so they can never move, had issues with 3d printer microswitches but they were super cheap, plastic printed mounts a nightmare on the Z. Conversly it's the X&Y that are the hassle with cnc with 3d printing they're nowhere near as important.
    I've not looked at Mach 3 or linuxcnc but I have assumed that the microswitchs have some software adjustment to compensate for inaccuracy when fitting the microswitchs I know grbl (And even Marlin for 3d printers both Arduino based) does so would be shocked if they don't.
    I figured one step at a time lol make router move and learn Fusion (These are at same time) then start with linuxcnc if I really struggle buy Mach3 but I'd rather use Linuxcnc been a linux used since 2005 big believer in opensource.
    I did also consider inductive sensors like I set up on my printer for the Z axis but the microswitchs I'm looking at have very high repeatability and the difference in accuracy between them is marginal, when I checked the datasheets the inductive sensors had a slightly higher accuracy but lower repeatability and in the end they were both in the 0.01mm range with is probably better than my router will be lol.
    I have no idea how to make sure the gantry is properly square though in the first place, pretty certain a set square isn't going to cut it lol.
  12. #139
    From what I hear, you are probably on a winner with the LCNC approach. When I built my first router around 5 years ago, it had single motors on each axis so gantry squaring wasn't an issue. Just as well as I was using LCNC which had no capability to home each end of the gantry separately. I ended up going to Mach3 and a CSMIO/IP-M motion controller for the Mk2, with twin X motors. This combination works really well - except that it doesn't home each end of the gantry separately either! However, I understand that this is functionality that is now in LCNC so you should be OK when you get to that point. I have a manual process to get round this but it would have been nice to just press a button and have it all happen automatically.
    I've had Z axis microswitch issues on my 3D printer - I know what you mean!
  13. The Following User Says Thank You to Neale For This Useful Post:
  14. #140
    Yes you are correct but it is only in the master branch (version 2.8) at this time and you can also alter the homing position on each axis in software just by changing an offset in the Machinexxx.ini file
    Have a look at Joe's excellent vids on building one.
    https://www.youtube.com/playlist?lis...zD30sZjtp_VyqY
  15. The Following User Says Thank You to Clive S For This Useful Post:
