07-09-2017 #181Parts came for the PSU this morning will build up over the weekend hopefully, I bought 4 capacitors instead of 3 should I fit all 4?
https://www.rapidonline.com/samwha-h...acitor-11-3121..Clive
07-09-2017 #182
Try again with the attachments
I bought 4 because I wanted a spare so I'll go with 3 ;)
the company I bought 4 AM882's from contacted me today they only have 2 so told them to ship them and refund the difference and bought 2 from HK angry though as I was expecting them to arrive next week now going to be at least 2 :(
When I finish the router and it moves properly I'm going to buy 1 3nm nema straight away to swap onto the X so I can swap the 2nm to the Z axis as I have a gap is bigger than I thought between the ballscrew and nema and the longer shaft of the 2nm motors are a perfect fit.Last edited by Desertboy; 07-09-2017 at 11:56 AM.
08-09-2017 #183
08-09-2017 #184
ignore wrong thread
09-09-2017 #185
Really am going to need to fit a dedicated 32amp line to the consumer unit, checked out the vacuum cleaners I have and 1 is 2.2kw and the other 1.8kw so if I use them both at once then that's 4kw lol.
What I need is an 800w cleaner for the dust shoe I think and dig out my vac pump or buy a 2nd hand one. At work I have infinite access to lorry air tanks (Used for the air brakes, raising suspension, etc) for free was thinking I could use a couple of them as vacuum tanks to increase the capacity of the vacuum pumps. I have compressed air on tap so less point fitting them for air.
I wonder how safe the air tanks are if I draw a vacuum on them, I think it would be wise to put them in some sort of box to give some protection against failure.
Was reading if I surface the MDF 1/16th both sides then I'll remove the non porous skin and the mdf will be permeable enough to suck through without holes I'm definitely going to have to try that.Last edited by Desertboy; 09-09-2017 at 07:05 AM.
09-09-2017 #186
Tried to spin my nema's up with the cncshield and arduino but no luck just a ticking sound from the motor's. I've spun all the motors up using a ramps board so will have to drag my printer to the machine to try again annoyed.
10-09-2017 #187
Bought myself a cheap spanner/ratchet set from banggood, missing 1/2 my spanners so have to borrow off others and they are getting annoyed.
https://www.banggood.com/12pcs-Profe...l?rmmds=search
click the EU warehouse and only £20 (£7 cheaper than China) now that never happens lol, uber cheap for Chrome Vandium. It's also good to have some cheap spanners so you whack them with a hammer which my snap on set is too expesnive for that sort of crap lol
I have 1/2 a snap on set and 1/2 a bluelight set (It's always the same ones missing lol)
13mm and 22mm are destined to always be in someone elses box, although I no longer need 22mm.Last edited by Desertboy; 10-09-2017 at 08:12 AM.
10-09-2017 #188
10-09-2017 #189
Very nice!
The Following User Says Thank You to Nickhofen For This Useful Post:
10-09-2017 #190
There are currently 84 users browsing this thread. (0 members and 84 guests)
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
