Page 20 of 63 FirstFirst ... 10181920212230 ... LastLast
  1. #191
    Just had a quick scan through, machine looks great mate, can't wait to see some vids of it moving.
    Alex
  2. The Following User Says Thank You to AlexDoran For This Useful Post:
  3. #192
    Excellent... what’s first on the list to cut?
  4. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  5. #193
    Making an arcade table for my mate's 40th bday, going to buy a decent solid oak (Or wallnut) table 2nd hand and rip it to pieces and reprocess the wood using the router.
    I want to make him something quite trendy looking, 22" lcd embedded in the table top, controllers in a drawer so when it's off it's just a coffee table.
  6. #194
    I suggest you replace those couplers before you start using your machine with Lovejoy/Oldham couplers. The one you have now are going to cause you trouble and eventually snap.
  7. #195
    I have got them on the list of things to do but I think it'll be a month or 2 before I can afford them need to buy the bits for my mates arcade table first so will probably use these couplings till after xmas and look at upgrading then. I can do the motor's at same time and only have to buy the hubs once.
    I think I got the nema's aligned straight enough for oldham couplings.
    http://www.arceurotrade.co.uk/Catalo...dham-Couplings
    I'm guessing I have to use 2 hubs and a torque disc?
  8. #196
    Yes, you need 2 hubs and one disc for each screw/motor. Actually you could also make those on your machine, which could save you the costs. I think they are pretty easy to make.
  9. The Following User Says Thank You to A_Camera For This Useful Post:
  10. #197
    Very slow movement with the ramps board ;) I had to explain to my dad that it would run quicker with the better electronics and PSU lol, I was repeatedly homing the Axis which is slow anyway.
    I finally bolted the bed together as well so all 28 bolts are in now, I will add another 4 pieces of 4545 to the bed at some point but bolted in with corners and T nuts because I'm not taking this frame apart for no man lol.
  11. #198
    Movement!!! :D
    Im a bit jelous!!
    Looks good but I understand that the speed (or lack of) is frustrating hehe
  12. The Following User Says Thank You to Nr1madman For This Useful Post:
  13. #199
    Moves good,looks good!:-)
  14. The Following User Says Thank You to Nickhofen For This Useful Post:
  15. #200
    Well done!
    First movement is always to be celebrated! That is when you start to treat it like a machine rather than a collection of inanimate objects.
    You say this is on a tight budget but it's got the right sort of bits and it will clearly cut stuff out for you. Keep going and you will be rewarded.
  16. The Following User Says Thank You to routercnc For This Useful Post:
There are currently 81 users browsing this thread. (0 members and 81 guests)
