24-11-2017 #361
I keep forgetting.. did you plan on using separate 5v psu or power it from usb?
If using psu then it looks tight to get that connected there as well...
24-11-2017 #362
The BOB is powered by usb, need to get 12v PSU in there yet ;) If I'm reading the BOB properly it can only be powered by USB unless you solder your own connections. If you have the same BOB get your male to male usb cable now ;) although you can hack something together at a push I originally powered it up with a hacked 4 pin molex (Hard disk power cable) to USB.
I hope the AM882 is a straight swap for the AM882h as I used the broken one as pattern for setting up whilst I'm waiting for the new one.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
24-11-2017 #363
24-11-2017 #364
24-11-2017 #365
24-11-2017 #366
24-11-2017 #367
24-11-2017 #368
I'm not sure about the AM882s, but with the software you can configure the EM806 so the fault output is active when ok (i.e. switched on), and goes inactive on fault (i.e. open circuit). That's how I configured my EM drives, which would allow you to loop through all the fault outputs and create a failsafe circuit.
The Following User Says Thank You to m_c For This Useful Post:
25-11-2017 #369
25-11-2017 #370
You are probably right about the AM882 also being software-configurable, but it looks as if getting a cable to be able to reprogramme the 882 and making all the configuration software work is another can of worms (judging by the experience of other people). I know it shouldn't be, but I didn't need to use the fine-tune facilities available through software and could manage with just the DIP switch options, so I chose not to change the factory setting for the alarm. That way I avoided any need to play with the configuration software. My thinking in this case was that normally you would be a bit more paranoid about NC connections, but here all the connections are hard-wired inside the box and so rather more reliable than anything going via plugs and sockets and around the machine itself.
Your recommendation is the better one; I chose to use a very slightly inferior option, and one that would be easier for the OP to use. Connecting in the fault outputs at all is a big leap forwards!Last edited by Neale; 25-11-2017 at 12:25 AM.
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
