26-05-2017 #10
Bit confused about what you are asking, what you linked to is literally just an inert container designed to hold oil and add it to a compressed air system to lubricate air tools.
You need a compressor, regulator (most compressors will have the regulator), an on/off switch (whether electronic solenoid or manual), and a nozzle. If you want mist, then really the best way to do it you will need two lines, one supplying coolant and one supplying air, ideally at different pressures (the coolant line only needs a very low pressure in my experience) and a mist coolant unit on the machine.
What you linked to wouldn't really be much use imo, the tank capacity is tiny - I use a 1 litre swimming pool filter container.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
