03-08-2017 #91
Would this power supply do?
http://www.ebay.co.uk/itm/800W-High-...AAAOSwPhdVJL-~http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
03-08-2017 #92
No. But you could make one for that price:
https://www.rapidonline.com/50a-brid...al-case-519318
https://www.rapidonline.com/samwha-h...acitor-11-3121
https://www.rapidonline.com/lcr-ep08...-clamp-11-3004
https://www.rapidonline.com/vigortro...-x-25v-88-0012
Some people might use 24-0 -24V secondaryLast edited by Clive S; 03-08-2017 at 09:53 AM.
04-08-2017 #93
Fixing become much more expensive when you order the wrong ones lol, I was convinced they were M10's that bolt the extrusion together they're actually M12 so £20 wasted on 30 M10 bolts and an M10 tap :( Ordered correct bolts going to try and wing it without a tap first.
Maybe I should build my own power supply has a certain geek factor to it ;)Last edited by Desertboy; 04-08-2017 at 11:21 AM.
04-08-2017 #94
I don't think you can screw a bolt into the extrusion without a tap I use these:- https://www.cutwel.co.uk/threading/m...1-tb804-series
In a battery drill.
Building a power supply is simple about one hours work...Clive
04-08-2017 #95
I doubt you will get an m12 bolt in without a tap.
3 piece set here for 8 quid... http://www.ebay.co.uk/itm/HSS-METRIC...NnuGfIi7lhU9Dg
The Following User Says Thank You to Zeeflyboy For This Useful Post:
04-08-2017 #96
Hi this is where the bolts are going into
You can get away without a tap if you use a decent impact driver but I've heeded your advice and bought one anyway lol might as well do it right. ;)
They sell bolts for self tapping into these I assume they have a more aggressive thread but I have used stainless A2's before untapped but that was with the 20mm extrusion which was very hard to do.
The 20mm is a solid circle though in the middle I think this would be easier to drive them in but might as well tap them. Annoying because I wanted to assemble the frame this weekend and bolt the rest of the Hiwin's on.Last edited by Desertboy; 04-08-2017 at 12:33 PM.
04-08-2017 #97
Yeah I've used the self tapping thread screws before, albeit m6 rather than m12. As you say they have a cutting type thread rather than the typical. Work well though, especially when you have a lot to do it's a big time saver over tapping.
your extrusion holes are a slightly different design to mine and looks easier to tap with those "tabs", I just know that even tapping mine to m12 was quite an effort. I just imagine you might risk shearing a bolt off trying to drive a thread that big with a normal bolt using an impact driver.... which might probably ruin your day, although m12 is quite meaty so that would take a lot of force I guess.
If you were closer you could have just borrowed my taps, but I guess just posting them to you won't work out much cheaper or quicker. No one near you that you could borrow from?Last edited by Zeeflyboy; 04-08-2017 at 01:30 PM.
04-08-2017 #98http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
04-08-2017 #99
I have just tapped 26 M12 in heavy extrusion, it take less than 20 secs a hole with the right tap.
04-08-2017 #100http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
There are currently 39 users browsing this thread. (0 members and 39 guests)
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
