  1. #10
    That's a shame, I have the big Evolution cutoff saw and I use it for all sorts of things, it did sterling service cutting a load of old thick wall galvanised imperial scaffold poles into manageable lengths, you need a squirt of WD for ally cutting to avoid clogging up the blade and you must clear the blade if you do clog it.
    Just don't try cutting Titanuim, it will eat the blade, don't ask how I know! ;-)
    - Nick
    The saw is really good it's the rest of the table that's crap lol, plastic has no place in a table saw! The fence is useless and the table is coming to pieces. I've often thought about taking the saw out and rebuilding it with a real table.
    I have an evolution mitre that's a lot better machine but still flimsy it's great for home use but if you've got any commercial uses I think Axminister is a better choice. My friend has done many a house up with his evolution but his tolerances are lot lower than mine.
    If you do get clogged teeth from aluminium I found cutting a bit of scrap steel cleans it out fine again but good advice I usually add a tiny amount of SAS (Think it's the same stuff as WD).
    Screwfix sell evolution compatible blades for 1/2 the price I have one on my machine at moment can honestly say they are as good the proper ones.
    As for eating blades also don't try and cut SBR25 rail with it either lol blunted the blade in and made a slight groove in the rail. Afterwards blades would not cut wood anymore just burn it ;)
    In the end I cut the rail with a £1 cutting disc and grinder in about 30 seconds, right tool for the job lol.
