23-09-2017 #11
Do you mean the limit switches? I wonder if they work like on an arduino/ramps combo with pull up resistors (Which you can toggle on/off) I know the inputs from the microswitches are 5v on the arduino as I had to use resistors to get the 12v from the inductive sensor down to 5v so I didn't fry the arduino and disable the pullup resistors. But when you use microswitches you have pullup resistors enabled and wire direct.
I do have an inductive probe that works reliably at 5v but running at 5v's reduces the detection distance so I would use a chunkier probe at 12v if I go this route.
I think though decent quality microswitches fitted properly will have high enough accuracy I wouldn't see a difference in real world performance.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
