Page 24 of 63 FirstFirst ... 14222324252634 ... LastLast
  1. #231
    I bow to your better knowledge - and the result of a straightforward experiment! Doesn't chime with the documentation or expectation, but if that's the way it works, then that's the way it works. Go to it, Desertboy, and do it Clive's way! I think that we're on the same page re input switches, though - connect between input pin and ground.
  2. The Following User Says Thank You to Neale For This Useful Post:
  3. #232
    Neale I am an old fart now. I worked on the good old day of valves. So from what I had read on the forum you outclass me by miles
    I spent hours some time ago with this card and thought as you did that the 12-24v was just for the 0-10v stuff. But there may be more than one version of the bob. Happy days.
  4. The Following User Says Thank You to Clive S For This Useful Post:
  5. #233
    Rather than old fart I think the terms experienced and seasoned are more suitable now I've turned 40 lol, when I was 20 then yes old fart.
  6. #234
    Nah, you're still a Bright Young Thing!
  7. #235
    I'm so glad I don't have to ask all the questions myself :D have the same bob on my table!
    Can't test it yet.. waiting for a cable :)
  8. #236
    Going to have a go at wiring it up at the weekend actual work has gotten in the way but going to be really busy until the 9th October so might not get a lot done until then.
  9. #237
    Fusion does produces nicer renders than turbocad for sure even with drafts.
  10. #238
    Good to see you're getting into the swing of things with fusion.
    The adaptive machining is invaluable... yesterday I was whizzing around with a 10mm roughing cutter at 2000mm/min and 10mm Depth of Cut - unthinkable with conventional machining strategies and such a relatively flimsy machine.
  11. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  12. #239
    Would be good to see a "how to" video or sequence when making Fusion renders - I can do basic stuff and have done some assemblies but nothing this good ;)
  13. The Following User Says Thank You to Davek0974 For This Useful Post:
  14. #240
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 1 Week Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    There is a very good one on Youtube, taught me alot about the options available for lighting etc. Im sure a quick search will find it.
  15. The Following 2 Users Say Thank You to Chaz For This Useful Post:
