    Little bit more done today, limit switches are fitted directly into the aluminium extrusion
ID:	23122 You can just see the red microswitch at the end of the energy chain a Hiwin carriage triggers it, there's identical switch on the other side in same position.
ID:	23123 And just under the bolt in the energy is the other switch only one bolt at moment need to find a 5mm piece of aluminium so I can fit the 2nd bolt but the edge is tight against the Hiwin rail so it's solid.
    I drilled them tapped the holes, very happy how they came out. There is no Z axis switch yet will rebuild the Z axis so they will be added then.
    Power supply is ready to be hooked up to the AM882's
    AM882's now have all the stall protection wired in
    The PC to control this now has windows 7 and Fusion 360 on it, and a parallel pci card installed. Wiring is in the energy chain just need to connect everything up, earth the spindle and connect solder that up and we can get it running.
    Need to get some wiring for microswitch just going to use cheap 2 core a junction box to split the power from the home built PSU to 4 steppers and some connector plugs will pick up on way to work tomorrow.
    How should I connect the CY cable to the nema cable, soldering or connectors?
