02-12-2017 #401
Smart stuff!
Any worries about soundlevels when running vacuumpumps?
Have never used one so I don't know but I'm worried :D
The Following User Says Thank You to Nr1madman For This Useful Post:
02-12-2017 #402http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
02-12-2017 #403
I use x8, with EM806. That's with NEMA23 3Nm, 5mm lead ballscrews, 1-1 pulleys. Seems like a good compromise between smooth running, resolution, and maintaining torque. Gives me about 5000mm/min rapid, which is slower than some people but the max I can manage with my ballscrew length.
03-12-2017 #404
8X it is ;) do the motors get quieter the more microsteps you have? When I first ran them one of the motors was virtually silent.
https://www.youtube.com/watch?v=O4_u5ov-9cc
Ordered a 720p webcam to set a timelapse up so I can record my mistakes ;)
Did you use the auto tune function on the EM806? Wondering if I did it right, flicked the SW4 switch on/off/on you hear some minor buzzing sound for a second and it's done. Does this sound correct?Last edited by Desertboy; 03-12-2017 at 08:22 PM.
03-12-2017 #405
Certainly a non-microstepped motor seems to run really roughly. I haven't studied it that closely, though - that was on a different machine which had been set up without microsteps for initial testing. The other thing to take into account is the pulse rate you can get out of the driving PC, though. Too many microsteps and you can't drive the pulses fast enough for decent speed. However, most people seem to be using external motion controllers these days which takes that whole issue away.
I did play with the autotune, although I was never quite clear about whether it should be done on load, and if so how you handled the case of a master/slave axis setup. Not a lot seemed to happen, though, and I have no idea whether or not it made a difference! I just use the machine, and it seems to work fine as it is. Might not be optimum, but I'm not sure what difference tuning makes. No apparent resonance over the speed range I use (typically cutting at around 3000-3500mm/min in wood or polythene) and 5000mm/min rapid. I guess that the ideal tune might allow slightly higher accelerations, but like a lot of people I just tweaked and tested until I had reasonable and reliable results.
Good luck - you seem to be getting close now!
04-12-2017 #406
I forgot to mention I fitted the BK12 fitting the wrong way round on the X axis and it was squeaking when I tried to move it, lubricated the hiwin's and ballbscrews a couple of times before I realised lol.
Swapped the BK12 fitting opposite way round and all good ;)http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
04-12-2017 #407
04-12-2017 #408
04-12-2017 #409
Aah.. thats the way I have it and still squeaking ;)
Have it reversed on z but that works fine haha
04-12-2017 #410http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
There are currently 39 users browsing this thread. (0 members and 39 guests)
New Table Build, 12x6 work area, drawings up any advice?
By silverdrgn in forum Plasma Table MachinesReplies: 3Last Post: 23-01-2016, 07:34 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
RFQ: acetal parts turned lathe work
By dazza in forum Projects, Jobs & RequestsReplies: 10Last Post: 13-06-2013, 10:15 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
