    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Yes you are correct they don't need to be accurate for limits and easier to connect in one loop.
    Am I right in thinking it's pointless to use limit switches if you're only going to wire them to the Estop as the home switches can do the same job? They become useful when fitted to an external override like a latched relay?
    Is this correct?
    Is this correct?
    You are thinking of wireing them to the estop input on the bob only?
    at moment yes I have crashed into the side of my machine already lol it's doesn't do a lot just fires a stall protect didn't meant to was see how close I needed to get to the microswitches. Something like Thor you got big issues but with 2nm and AM882's it seems a non issue.
    since all my switches with wired NC if the machine fails to stop machines probably crashed and stuck in a loop which is probably extremely rare in linuxcnc.
    I know lots of people trust bob inputs and software and do similar installations like you are planning. It was this forum that made me question this and think more industrial ;)
    But almost all of the time your way will work haha
    When I got steel things will be different
    Well.. if you use latching relay option that might fuse aswell as software.. you are never totally safe :D
