  1. Hi Guys, i have been hiding for a while, so long infact i think i have forgotten how to use this post,
    So a problem has started to happen, generally when i set up a new job and zero the z either with a touch plate or by eye when i run the program the z is now +4mm above where i set zero, anyone have any clues to this
    Thanks roger CNCEzee
    Neale's Avatar
    Lives in Plymouth, United Kingdom. Last Activity: 10 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Does your tool-zeroing macro have the right dimension for the touchplate? Let's start with the obvious ones
  3. Hi Neale, Thanks for replying.
    well i think so, what seems to happen is that the tool tip will touch off raise the required amount stop briefly then raise another 4mm, software coding is the quickest way there is of confusing me, i will strip out that code and try it with out.
    Roger
    You haven't got a 4mm work offset in the tool change tab have you?
    Neil...
    Build log...here
  5. Good Question, i don't know but i will check when i get down there.
  6. No Not any tool or work offsets
  7. No just checked also just removed code from touch plate, zeroed the maching cilcked go to zero zeroed perfectly, run tool code machine is +4mm stop machine re-zeroed runs as should...GRRRRRRR
  1. Auto zero Z axis problems
    By Jumbo in forum Probing, Digitizing & Scaning
    Last Post: 23-10-2016, 03:00 PM
  2. Mach3 Problems problems problems.
    By ECCO in forum Artsoft Mach (3 & 4)
    Last Post: 09-07-2016, 10:07 AM
  3. MACH 3 2010 Screenset Zeroing Macros
    By Washout in forum Artsoft Mach (3 & 4)
    Last Post: 12-01-2014, 01:15 PM
  4. Z AXIS, big tex blue screen and auto tool sensor Problems
    By Tomnewry in forum Artsoft Mach (3 & 4)
    Last Post: 01-01-2014, 09:01 PM
  5. Boxford VMC190 Retrofit Problems, axis sounds very rough
    By mikegolding in forum Boxford Vertical Mills
    Last Post: 09-06-2013, 09:11 PM
