Page 2 of 2 FirstFirst 12
    ...but 12V 6.5W is over 500mA, so if he is going to use the solenoid on the picture he needs a transistor, or a small relay in between the valve and the 555. The 555 is OK for small relays but not for solenoids.
    I did not mention a solenoid
    Wal's Avatar
    Right, got this made now. It's flung together into an empty air-rifle pellet tin I had lying about, but it seems to work alright...
    I eventually used this circuit.
    ...you can get essentially the same thing for half the price here - I assumed at the higher price that this was pre-soldered - it wasn't..! The two pots that control the interval/pulse are a bit sensitive, but otherwise it's a decent enough kit and very easy to put together. I didn't need the fly-back diode after all.
    Thanks to Clive for suggesting the switch to over-ride the circuit and keep the air on continuously - useful and pretty much a necessity..!
    Here's a vid of it in action:
    And for fellow electronics dunces, here's a diagram of how it went together:
    Wal.
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Glad you have it fixed up and running Wal. Have you put a grommet around the red/black wires out of the tin ? to stop chaffing.
    Wal's Avatar
    Hi Clive, I didn't have any grommets to hand, so I've hot glued (around the holes) all wires going in/out... stops 'em moving about.
    Wal.
  1. NEW MEMBER: First timer
    By bofred in forum New Member Introductions
    Last Post: 01-12-2014, 09:23 PM
  2. EMI Filters, any purpose in a diy control circuit?
    By GTJim in forum General Electronics
    Last Post: 14-03-2014, 11:38 PM
  3. Custom Vacuum Table 'Hold Down' System - piping/valve advice
    By FlightCaseCo in forum Machine Discussion
    Last Post: 16-01-2012, 06:56 PM
  4. TB6560 > Timer > GMFC
    By Theo in forum Motor Drivers & Controllers
    Last Post: 17-10-2010, 06:59 PM
  5. NEW MEMBER: Old timer, still learning, Virginia, USA
    By GerryR in forum New Member Introductions
    Last Post: 13-10-2010, 10:41 PM
