Thread: Feeler FTL 618
  1. Not much use rebushing the idler gear, it's well worn (no teeth left)
    That's a bugger!
    Hardinge gears use an obscure DP (18?) and pressure angle. Feeler may not have copied it exactly. It'd be a good idea to double check them before you buy an expensive Hardinge part
    [edit] It's well worth stripping down the carriage.There are oil ways and pipe in the rear of the HLV that should be checked while you're there.
    oil distro
    BTW later HLV-Hs (not mine :() had a PTFE/teflon coating on the underside of the carriage. Careful, if your Feeler has the same, it is apparently fairly soft and easily damaged.
    [edit]
    Phew - Just realised you were talking about the EM dial idler gear not the carriage drive gear!
  1. REBUILD: Another Feeler FTL 618
    By Graham Stabler in forum Lathe Rebuild Logs
    Last Post: 28-05-2014, 10:04 PM
  2. WANTED: Hardinge hlv-h or Feeler 618
    By cookie in forum Items Wanted
    Last Post: 26-02-2011, 09:09 PM
  3. Feeler FTL 618 Lathe
    By pfincham in forum Milling Machines, Builds & Conversions
    Last Post: 04-08-2009, 06:35 PM
