Thread: Feeler FTL 618
22-10-2009 #38
It's coming on nicely :)
Do you have the covers and levers in place? If not you'll be feeling the cross-slide gears spinning as you move the carriage. [one nice Hardinge feature is the ability to cut a perfect 30' taper by engaging both cross-feed and carriage feed at the same time]Bill, if your out there is it likely that the clutches are making the drive feel tight??
I can only just feel the clutch drag on the cross slide if I wind the handle fast. Otherwise, the clutches are free.
The clutches should be adjusted to "...engage and disengage when the ball lever is between 10' and 20' above horizontal."
REBUILD: Another Feeler FTL 618
By Graham Stabler in forum Lathe Rebuild LogsReplies: 7Last Post: 28-05-2014, 10:04 PM -
WANTED: Hardinge hlv-h or Feeler 618
By cookie in forum Items WantedReplies: 1Last Post: 26-02-2011, 09:09 PM -
Feeler FTL 618 Lathe
By pfincham in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 04-08-2009, 06:35 PM
