    Quote Originally Posted by mikeconcannon View Post
    I havn't rewired the machine and connections 1, 2 and 3 on the four pin plug/sockets go to the VFD and pin 4 goes to earth, all looks OK there .
    Any ideas anybody, before I go and buy a new 1.5kw 80mm ER16 spindle to replace this one ??
    thanks in advance, mike Galway, Ireland
    A water cooled spindle would not get that hot in 30min Do you think the guy has altered the vdf settings I would disconnect the spindle and check the perams. Also using an ohm meter check the resistance between the 3 cables to the spindle and also to earth.
    No it's not water cooled and it's not aircooled with fan assist either, its just a cylinder of steel. I originaly bought it in 2005 so probably before the better cooled spindles we have these days.
    It was suggested to me today,. that it is perhaps a 110 volt spindle and that the fella that the machine was with, swapped my good 240 volt one for this 110 volt one, does that sound feasible? is there any way to check if a winding on a motor is 240v or 110v?
    VFD set to 240v out with a 110v spindle, are you allowed top swear on this forum
    Do you now have it working as it is not clear from the above. Have you set the parameters up in the vfd?
    Iv put the parameters right now, the spindle is 110 volts, I had 220 volts set in the output of the VFD and that is why the spindle was getting hot. I have changed the output to 110 volts now and its running cool again
    It doesn't seem like there is any cooling atall on this spindle, it is 80mm diameter about 230 long. It was bought around 2005. I cant see aircooling gaps and its definately not water cooled. This is running fine now and does not get hot but does anyone know if I would be making the right move by getting a 240 volt watercooled one.
    How about a pic. They are either water cooled with two pipes on the top or air cooled, If it is air cooled it will be noisy.
    But if it works !!
  1. CNC gone wrong
    By martythunder in forum General Discussion
    Last Post: 16-02-2017, 04:21 PM
  2. When it all goes wrong
    By alboy in forum General Discussion
    Last Post: 12-12-2015, 01:16 AM
  3. What has gone wrong????
    Last Post: 05-09-2014, 12:25 AM
  4. Ok, so whats wrong?
    By Davek0974 in forum 3D Printing Machines
    Last Post: 27-03-2014, 12:19 PM
  5. Help with 1.5kw Chinese spindle. Wrong plug.
    By adamh in forum Generic Chinese Spindles
    Last Post: 14-01-2014, 07:36 PM
