Thread: HIWIN Grease Fitting Extension
03-05-2017 #10
We have both manual central lube systems and auto lube systems installed on some of our machines at work. Both work well but I prefer the manual lube, as long as the operators remember to use them at the start of their shifts. The issue I have with the full auto lube system is over greasing. Apart from them supplying grease at their timed intervals they also supply grease when they are powered on to start their cycles so this means that every time we have an emergency stop situation with either a light guard being broken or collision sensor operating the auto lube restarts it cycle when the power has been restarted. We can have quite a few extra grease operations during shifts.
4 pin extension leads
By GaryWilliams in forum Chinese MachinesReplies: 11Last Post: 24-12-2021, 12:27 PM -
Do you grease HiWin rail Sliders?
By AndrewMawson in forum Linear & Rotary MotionReplies: 2Last Post: 09-01-2017, 04:15 PM -
.GD4 file extension ?
By greenz123 in forum CAD & CAM SoftwareReplies: 7Last Post: 30-06-2015, 12:44 PM -
Ballnut Lubrication / Grease
By Mad Professor in forum Lead Screws, Nuts & SupportsReplies: 3Last Post: 18-07-2012, 08:08 PM -
Limiting unsupported extension on Zaxis.
By Rogue in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 03-09-2011, 12:30 AM
