Thread: Router spindle idea
Cartridge grinding spindle, not seen that taper fitting before, could be a short form of INT / BT 30 taper as they are 1.25" on the gauge line diameter which is close to 32mm.
Usually very high class bearings fitted to these. What about using one of your low voltage motors as a source of motor?
.John S -
07-08-2009 #2
Did think about using one of 24v DC motors but thought the power supply maybe a problem. They draw about 7-10A at idle and up to 125A max when under load, i know it would not need 125A to drive a spindle but what would it cost for say a 30A PSU???
I already have the digital speed controllers to run it so it does make sense, just don't fancy running it off a couple of battery's!
19-01-2010 #3
This look like a spindle from an internal grinder, so the bearings should be very good.
Please review this router gantry idea
By EddyCurrent in forum Gantry/Router Machines & BuildingReplies: 34Last Post: 09-09-2013, 04:47 PM -
options for 3020 router spindle?
By arborealad in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 19-11-2012, 10:13 PM -
WANTED: Router Spindle Motor
By swinds in forum Items WantedReplies: 3Last Post: 26-04-2012, 10:43 AM -
New spindle idea for my machine - DC 1HP
By HiltonSteve in forum Electronic Project BuildingReplies: 35Last Post: 29-08-2010, 07:20 PM -
Router/Spindle choice for Makita laminate trimmer upgrade
By CraftyGeek in forum Makita Routers & TrimmersReplies: 7Last Post: 30-11-2009, 11:23 AM
