Page 15 of 35 FirstFirst ... 5131415161725 ... LastLast
  1. #141
    http://www.beltingonline.com - Very good to deal with.
    Thanks for the reply, are there any pulleys with a 10 mm hole already in the middle,or I am missing something,I can find only with 6 and 8 mm HDT5 pulleys at beltingonline.
  2. #142
    Where can I find HDT5 pulleys with 10mm bore, any suggestion?
    Not sure if this helps, but I just ordered some on eBay in US. from China:
    https://www.ebay.com/itm/HTD-5M-20T-...72.m2749.l2649
    I figured they wouldn't ship until after Chinese New Year, but they are supposedly on their way. Obviously, I can't yet speak to quality...
    Regards,
    Wallace
  3. #143
    Thanks Wallace, I will check them!
  4. #144
    They quite often just have pilot hole but have you asked them if they can bore them out for you, don't forget grub screws
    I have just checked http://www.beltingonline.com/20-toot...20-5m-15f-7776 there is an option for the boring and grub screw holes. bit expensive thou , not hard to do.
  5. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  6. #145
    I usually let them do it, its a bit of faffing about that i can do without for the sake of 3 or 4 quid, plus getting the grub screws as well :)
  7. The Following 2 Users Say Thank You to Davek0974 For This Useful Post:
  8. #146
    Thanks guys, I just login to report that I saw that there is an option for modifying bore etc. and see your answers!
  9. #147
    https://www.aliexpress.com/item/1PC-...ceBeautifyAB=0
    I found those at aliexpress, they are made from aluminum alloy come with 10mm bore and two screw holes.
    I am going to use 1/1 ratio for X Y and 1.5/1 for Z , are those any good, anyone has experience with those?
    Any suggestions about the belts?
  10. The Following User Says Thank You to Nickhofen For This Useful Post:
  11. #148
    Just notice that they seems to be the same with those Wallace suggest ,with no shipping cost...
  12. #149
    Hey Nick!
    If you have the right length on your end machining on the ballscrew I think it's better to use pulleys with a shoulder with the setscrews and not the ones with bored out teeth.
    I think it's kinder on the belt :)
  13. The Following User Says Thank You to Nr1madman For This Useful Post:
  14. #150
    Thanx for this link :-)
    Need to order too.
    Grtz Bert.
  15. The Following User Says Thank You to driftspin For This Useful Post:
There are currently 13 users browsing this thread. (0 members and 13 guests)
  1. cnc 4axis hot wire mach3;
    By maikonesk in forum Hotwire Cutting Machines
    Last Post: 07-08-2015, 02:15 PM
