Thread: 1200mmX900mmX170mm 4axis cnc
29-03-2018 #191
15-04-2018 #192
The Following User Says Thank You to Nickhofen For This Useful Post:
15-04-2018 #193
Brill
It is good practise to not to daisy chain the 70V across each drive ie. use separate power leads from each drive to a common block and then connect the PS to the block. This ensures you are not getting a volt drop to each drive from the first one...Clive
The Following 2 Users Say Thank You to Clive S For This Useful Post:
15-04-2018 #194
Thanks Clive, I will keep this in mind!!!
15-04-2018 #195
That's super tidy, I see you went DC in the end. What voltage output transformer is it? 50v?
I wired the transformer to a 13 amp light style switch and then my VFD and water pump to another switch and both of them are wired from the emergency stop.
This way I can easily turn the transformer on/off and if the vfd is powered the water pump is on. I have both switches and the emergency stop at the front of the machine for easy access in a row.
If I hit the emergency stop it kills power to both the steppers and the vfd, I still have to work out how to get it to trigger an estop on the pc but it's good enough for me at the moment.Last edited by Desertboy; 15-04-2018 at 01:36 PM.
15-04-2018 #196
15-04-2018 #197
15-04-2018 #198
Nice progress!
Does it feel good to move forwards? :D
15-04-2018 #199
In my case it would be good to get back to where I started - spent the afternoon reassembling my lathe and getting the safety switches operating reliably. Then reinstalled the VFD (when I took it out months ago to fix the broken mounting lugs, I photographed the connections and labelled them as I disconnected each one). Now I am getting a code that says low DC bus. I sense a new thread coming if I can't sort it easily.
15-04-2018 #200
cnc 4axis hot wire mach3;
By maikonesk in forum Hotwire Cutting MachinesReplies: 3Last Post: 07-08-2015, 02:15 PM
