    A bleed resistor might be useful while you are testing, but once you have a driver or two wired to the power supply, they look like a waste of time. When I checked my machine, the stepper driver power supply was down to a few volts within seconds of cutting power. Any resistor that drains down faster than that is going to need to be a fairly high wattage item, and is going to produce more heat than you probably want in the control box.
  2. The Following User Says Thank You to Neale For This Useful Post:
  3. #2
    Provided that the drivers are energising the stepper coils, and are connected, and that there are no failures in the system, and that there is no e-stop isolation.
    I'll spend the £1 extra on any >50VDC PSU. Pays your money, takes your choice.
  4. The Following User Says Thank You to Doddy For This Useful Post:
  5. #3
    I know on the AM882 when you kill power the LED's flash for ~3-4 seconds extra then when you test the capacitors they drop to a few volts. Same with the VFD so I assume that has a load of capacitors as well, also if you notice PC's do the same thing.
    I think it was joe's build where he used a resistor to drain the capacitors which I was going to do but given the AM882's drain them anyway I figured it wasn't a major issue.
    I've been shocked with 240v a few times over the years lol but the worst shock I ever got was from a Playstation 2 PSU for several days afterwards I felt in physical shock, last shock was direct from the board lol we have old school fuse holders at work for each phase and one of the fuse holders was missing the screw caps so when I pushed the fuse into the board I was touching the screws than was fun ;)
    Oddly enough I went through every fuse holder and chucked the ones missing the caps after that.
  6. The Following User Says Thank You to Desertboy For This Useful Post:
  7. #4
    I am starting to flirt with the idea of UC300eth and UB1 any opinions and ideas from where to buy are welcome.
  8. #5
    I recently purchased my UC300eth and UB1 combo from CNCRoom and UCCNC software from CNCdrive! Its a smaller world nowadays...
  9. #6
    Quote Originally Posted by Krammer002 View Post
    Thank you for the reply, have you give it a try yet?
  10. #7
    It'll be a while before I'm ready to deploy the control system fully, but I will be bench testing in the near future...
    I've also purchased the 2017 screenset from Gerry - CNCwoodworker . with a view to creating my own screenset in due course!
  11. The Following User Says Thank You to Krammer002 For This Useful Post:
  1. cnc 4axis hot wire mach3;
    By maikonesk in forum Hotwire Cutting Machines
    Last Post: 07-08-2015, 02:15 PM
