    Yes Bert what you say it's true, UB1 needs only 24volts which converts it to 5 volt , with some restrictions,has on board 3 relays , from those you can control a sequence , powering up power relays etc.and other features.
    My problem is that it is more complicated than the one and only 5$ bob I have ever install, at my previews cnc and also much more expensive, the last one makes me more nervous to experiment! I must be a 100% sure before power it up!
    My parts are:
    2x AM882H
    2X AM882
    1x78Volts PSU 7Amps
    2x12 volt psu 330watt
    HY VFD with 2.2kw water cooled spindle
    water pump...etc.
    I hope I did n't forget a major component , if i remember something I will edit my post.
    Thanks,Nick.
    Any home switches?
    Do you want to control spindle speed by 0-10v?
    Estop?
    Air valves?
    cooling pumps?
    Grtz. Bert
    Quote Originally Posted by driftspin View Post
    Any home switches?
    Estop?
    Air valves?
    cooling pumps?
    Grtz. Bert
    Right now I have the Estop ,NPN proximity switches and water pump.
    I will add all the rest ,everything I can add and also a potentiometer for spindle speed control.
    I posted this some time ago. #1 http://www.mycncuk.com/threads/7388-...se-Spindle-VFD
  4. The Following User Says Thank You to Clive S For This Useful Post:
  5. #4
    Try to make a diagram with the help of UB1 manual....
  6. #5
    This is what I come up untill now, no water pump or stepper motors yet added.
    HY VFD is going to be connected according the second schematic.
    Can you guys check the diagram to see if you find any issues, I add also the manual of UB1.
    Also please suggest where to put fuses and relays.
    Thanks,Nick.
Name:	UC300 ETH_UB1 WIRING DIAGRAM.png
Name:	connection of vfd HY to UB1.png
    http://www.cncroom.com/downloads/UB1...al%20E15R0.pdf
  7. #6
    One thing I see is that you seem to have fuses in the -ve line from the 72v PS that is NOT good practise and are not necessary. Also 5A may be a bit low
  8. #7
    Not a good practise at all ,I didn'r realyse I put the fuses there.
    I change it .Thanks!
  1. cnc 4axis hot wire mach3;
    By maikonesk in forum Hotwire Cutting Machines
    Last Post: 07-08-2015, 02:15 PM
