    Came from work today and a box was waiting for me,motors are here!
    AM882 are one their way home and I have to decide about the breakout board, any suggestions?
    Nice, 3nm?
    https://www.ebay.co.uk/itm/5-axis-CN...4AAOSw4DJaZvGY
    These are compatible with Mach 3 and Linuxcnc but if you want to use Mach 3 it has restrictions no later than Windows 7 and 32bit only. Step generation is done by the processor on the PC performance can be very acceptable and it's a very cheap place to start it also has proven reliability people have run setup's like this for over a decade now with no issues. You will need an old pc pentium 4's work well and have parallel ports built in generally.
    Other options normally are step generators and cost a lot more but performance will be better, one to watch is boards are generally Mach 3 or Linuxcnc not both. Mach has a lot of USB controllers which work via plugins linuxcnc has no usb options at all! USB is crap TBH and should be avoided. Not sure what other options for Mach 3, Linuxcnc everyone gets a Mesa card be it PCI or Ethernet.
    You could also buy a ddscv see Boran's excellent thread, for the price not a bad choice at all and I was tempted.
    If you want dual homing on the Y axis (so it squares the gantry automatically) mach 3 or linuxcnc is your choice can be accomplished with a cheap breakout board. In the end this is what swumg it for me to stick with linuxcnc rather than get the standalone controller.
  2. The Following User Says Thank You to Desertboy For This Useful Post:
  1. cnc 4axis hot wire mach3;
    By maikonesk in forum Hotwire Cutting Machines
    Last Post: 07-08-2015, 02:15 PM
