Thread: 1200mmX900mmX170mm 4axis cnc
14-06-2018 #241
14-06-2018 #242
Hi Nick,
You just made me regret not buying a UB1.
Keep up the good work!
Grtz. Bert.
14-06-2018 #243
Sorry Bert,I didn't have this intention!
14-06-2018 #244
To much heat at the workshop this time of year,so I am going to start the electronics wirring .
Any diagram to follow?Last edited by Nickhofen; 15-06-2018 at 04:23 PM.
15-06-2018 #245
The Following User Says Thank You to Nr1madman For This Useful Post:
15-06-2018 #246
I was lucky with the motor mount ,I just too advantage of the one end of the heavy duty aluminum beam,it was made like that and I cut it with the grind cutter.
About the diagram I want some thing that will work and not burn any driver or something else,haha
16-06-2018 #247
I followed this schematic
Its made by a forummember "euricain" I Think..
Then there is this from jazz
And I also found lots of inspiration from this. I think it was routercnc that made this one..
16-06-2018 #248
Thanks Robert.
I had the number one and number three schematic,thanks for the second one.
Can I ask why you follow the first schematic?
Yes the last one is mine. Since then I’ve changed the Z drive to DQ860MA to match the others and run off the 68V supply. That allowed me to remove the 30V supply.
As my new Mk4 machine uses 2 Z steppers I’ve added another DQ860MA drive off the same supply so there are 5 drives in total. Otherwise all the safety relays and interlocks are the same. Works well.
16-06-2018 #250
I was set on using the schematic from jazz since I started my build.
Then I read the thread about the first I posted and thought it made sense..
The one from routercnc has alot of extra benefits like bleed resistor and ability to change vfd speed manually.
But I still went with the first :D
cnc 4axis hot wire mach3;
By maikonesk in forum Hotwire Cutting MachinesReplies: 3Last Post: 07-08-2015, 02:15 PM
