Page 31 of 35 FirstFirst ... 212930313233 ... LastLast
  1. #301
    Chaz's Avatar
    I am thinking to place the parts that way in the control box,will it be any problem with the positioning of VFD?
    If I remember correctly people puts shielede cables to the signal wires ,wires that goes to controllers, motors etc. right?
    Attachment 25119
    The manual for each device will tell you what spacing you need for cooling, follow that.
  2. #302
    Attachment 25119
    I personally prefer the VFD outside of the control box. The spacing on the drives are fine I tend to use cat3 twisted for the signal wires and CY 4 core for the motors the shield grounded to the star point at one end only
  4. #303
    Thanks guys!
    Clive CY4 core for the motors and parallel wiring for the motor's coils right?
  5. The Following User Says Thank You to Nickhofen For This Useful Post:
  6. #304
    Thanks guys!
    Yes 1mm cable is ok. and parallel assuming you have 8 wire motors yes
  7. The Following User Says Thank You to Clive S For This Useful Post:
  8. #305
    8 wires of course,I forgot to mention it
  9. The Following User Says Thank You to Nickhofen For This Useful Post:
  10. #306
    My layout is a mirror image of that because the VFD air inlet is on the left. I cut out a large hole in the side of the enclosure next to it to allow the air straight in to the VFD and the it exhausts out of a hole directly above it. That stops it drawing warm air from the enclosure.
    I allowed 2 80mm fan sized holes in the base of the enclosure below the drivers but never added the fans as they barely get warm. Natural convection seems to work fine although we are in the UK so it does not get that hot.
  11. The Following User Says Thank You to routercnc For This Useful Post:
  12. #307
    Thanks routercnc.
    I have in mind to use two fans on the bottom of the enclosure box to push air in there and a filter for the dust and two on the top.
    The info about the hole near VFD is very good,I am going to use it!
  13. The Following User Says Thank You to Nickhofen For This Useful Post:
  14. #308
    This week a friend ask if I want one of those big PC tower for housing the electronics of the cnc, I said yes and he came with a box bigger than I could think!
    Ι did some mods on the box...
  15. #309
    Some more drills, screws, rivets and , here is the result!
  16. #310
    Hey Nick,
    I like it that you are making progress.
    Keep up the good work.
    Grtz Bert.
  17. The Following User Says Thank You to driftspin For This Useful Post:
  1. cnc 4axis hot wire mach3;
    By maikonesk in forum Hotwire Cutting Machines
    Last Post: 07-08-2015, 02:15 PM
