Thread: 1200mmX900mmX170mm 4axis cnc
	12-02-2018 #141
	12-02-2018 #142
Not sure if this helps, but I just ordered some on eBay in US. from China:
https://www.ebay.com/itm/HTD-5M-20T-...72.m2749.l2649
I figured they wouldn't ship until after Chinese New Year, but they are supposedly on their way. Obviously, I can't yet speak to quality...
Regards,
Wallace
	12-02-2018 #143
Thanks Wallace, I will check them!
	12-02-2018 #144
They quite often just have pilot hole but have you asked them if they can bore them out for you, don't forget grub screws
I have just checked http://www.beltingonline.com/20-toot...20-5m-15f-7776 there is an option for the boring and grub screw holes. bit expensive thou , not hard to do.Last edited by Clive S; 12-02-2018 at 05:31 PM.
The Following 2 Users Say Thank You to Clive S For This Useful Post:
	12-02-2018 #145
The Following 2 Users Say Thank You to Davek0974 For This Useful Post:
	12-02-2018 #146
Thanks guys, I just login to report that I saw that there is an option for modifying bore etc. and see your answers!
	24-02-2018 #147
https://www.aliexpress.com/item/1PC-...ceBeautifyAB=0
I found those at aliexpress, they are made from aluminum alloy come with 10mm bore and two screw holes.
I am going to use 1/1 ratio for X Y and 1.5/1 for Z , are those any good, anyone has experience with those?
Any suggestions about the belts?Last edited by Nickhofen; 24-02-2018 at 12:38 PM.
The Following User Says Thank You to Nickhofen For This Useful Post:
	24-02-2018 #148
Just notice that they seems to be the same with those Wallace suggest ,with no shipping cost...
	24-02-2018 #149
Hey Nick!
If you have the right length on your end machining on the ballscrew I think it's better to use pulleys with a shoulder with the setscrews and not the ones with bored out teeth.
I think it's kinder on the belt :)
The Following User Says Thank You to Nr1madman For This Useful Post:
	24-02-2018 #150
The Following User Says Thank You to driftspin For This Useful Post:
cnc 4axis hot wire mach3;
By maikonesk in forum Hotwire Cutting MachinesReplies: 3Last Post: 07-08-2015, 02:15 PM
